RF transisitor info?
fasteddy
377
2
26
The other night I ran across a website with a lot of info on Rf transistors, and like a dummy I didn't save it. Anybody help me out with a site that has the same info?
Thanks
Ed
KC0PZE
I think I have a good link to a site at home.I am at work right now but will try and find it and post it for you tonight.I remember that the link I had was a really good one with PDF files on the transistors.Hopefully I didn't lose it.
Well I had a look and sorry Ed but I am sure I had a link to a site where you could look up transistor types including RF types and then get a PDF data sheet on them but it is gone.I did however find some kids files in with my HAM STUFF folder in my favorites. Hmmmmm...?? :? :(
Brew, thats not it, but thanks alot. Garth, sounds like you have the same problem I have, kids like the internet too :D
Thanks guys
Ed
KC0PZE
Hope this helps a little.
HI POWER TRANSISTORS 27MHZ.
12.5VDC TO 13.6VDC
TRANSISTOR#/POWER OUT/POWER IN/MOUNT
MRF450 50w 4w FLANGE .380
MRF450A 50w 4w STUD .380
MRF453 60w 4w FLANGE .500
MRF453A 60w 4w STUD .500
MRF455 60w 3w FLANGE .380
MRF455A 60w 3w STUD .380
SRF2072 65w 3w FLANGE .380
SD1446 70w 7w FLANGE .380
MRF492 70w 5.6w FLANGE .500
MRF492A 70w 5.6w STUD .500
MRF454 80w 5w FLANGE .500
MRF454A 80w 5w STUD .500
2SC2290 80w 4w FLANGE .500
SRF3749 85w 5w FLANGE .500
SRF3800 100w 4w FLANGE .500
2SC2879 120w 7w FLANGE .500
RF TAB MOUNTING TRANSISTORS-27MHZ
TRANSISTOR # INPUT POWER CW OUTPUT POWER PEP
MRF477 1.2W 40W
MRF497 1.0W 60W
2SC1969 1.0W 22W
2SC2166 0.2W 14W
2SC2312C 1.2W 30W
2SC1306 SEE 2SC2166
2SC1307 SEE 2SC1969
You might try this link to NTE. www.nteinc.com/Once there you can either use the online reference or download the cross reference software called QuickCross.Don't worry about filling in the little form in order to download it.It is necessary but I have never had spam or the like from them.You just enter the transistor type number and it cross references it to the NTE type and provides link to PDF data sheets.I use it at home and at work.I forgot all about this one. :oops:
    535A has left the room.
