Hello.
Something I noticed when trying to set the gate bias voltage of the RM Italy amp I was trying my hands on to fix, it seems that setting the voltage of the gate bias to 3.6v, the amp would behave erratically on SSB. The relay sometimes would not click back off, and the relay would sometimes stay on the entire time until you clicked the amp back off. Putting the gate voltage to around 2.2v seemed to of remedied the problem. Amp will now operate as it once did and no problems with the relay clicking back off when you unkey. Am I overlooking something that is causing the problem or is lowering the voltage of the gate to 2.2v not a good idea? I am using the FQP13N10 transistors as thats what I had.
All the help so far is greatly appreciated.
