Retevis is giving away Radios for the New Year and Every Member is Eligible. Click Here to see the details!
Tom has some good info on this amp at this link: RM HLA-150 test It will probably run best around a 25 watt carrier with the peaks reaching 100 watts according to this report.
It works well low drive i set my
carrier @ 1/2 watt the rm has a
25 watt carrier with 100 pep its clean
and Linear, i can run it all day no problems
it has 2 fans. no worry for heat build up in
long qso,
Need help lost my channel chart . Cobra 148 GTL with a 8719 and 11,1125 crystal 26.175 to 28.045 , Need the chart I can fill in the blanks slide 2ck up and 12 kc down
