You able to understand schematics?
In the above, locate J13 and J14 - SSB Delay...short to enable.
Locate J17 and J18 - POWERS SSB MODE - changes BIAS from Class C to AB.
J9 and J10 - APPLY power for BIAS - provides power to J17 so J18
Note the J3 and J8 are INPUTS for a Resistor Padding section that affects the level on INPUT power - this is controlled thru the front panel of the Amp but you may need to tweak resistor values to make this concept work.
Found Schematic here...
https://www.rmitaly.com/wp-content/uploads/2018/10/834_Manuale_Tecnico_KL_503_rel_1.2-1.pdf
I've just been doing a bit if reading around, and some say audio on SSB is dismal without a mod' - others as per this thread say it's fine.
Does anyone know what the modification is?
For best SSB audio and performance a class AB amplifier is preferred. Class B will also work well like the old Magna Force and TnT line from X-Force. Many amplifiers are class C and the builders add either an auto or switched SSB delay to them. They work on SSB but some people will say they can sound crunchy on SSB. If you are looking for an amplifier for SSB most of the time I would just buy a class AB amplifier.
If you run strictly 10M - this amp is ok - but the problem begins when you go out of band.
See that Schematic? That "input" side RTX (L1 thru L4) is what is called an SWR block - it a notch filter - designed only to pass 10M and 12M and below - but BLOCKS 11M operation - sends it to ground - and causes a High SWR condition.
To defeat that - refer to the schematic. There are two caps - choose wisely.
I've been told in a couple of places now that the KL505 works fine on 11M (CB frequencies) out of the box, but post #11 says otherwise.
Many say the KL503 sounds pants on SSB, others say good, so I guess I'll have to buy & try the KL503 at a later date.
My new KL505 is due here on Monday, so I'll report my findings as to whether or not it will work on 11M out of the box.
