Robyn SB-520 (858 PLL) no 7.8 reading and overheating capacitor
Lkaskel
I Support WorldwideDX.com!
Aug 4, 2017
521
433
Hi Gang,
I have an SB-520 on the bench doing an alignment. The radio has been re-capped. In the synthesizer alignment section I made all the way to the last 2 steps (the 7.8Mhz adjustment). I got no reading on the freq counter at TP-9 and C101 (closest to the edge of the board) was nuclear hot. I quickly made sure it was in correctly (not reversed) and it was. I shut the radio off to keep from any damage. Any thoughts why there would be no 7.8 at TP-9 and C101 is on fire? I did pull a Washington with the 858 board and verified things and I could get a reading at TP-9 and C101 was not hot.
Thanks as always!!!!
