I have a Magnum S9 that I am planning on using in a Peterbilt Daycab truck. I've used the Wislon 1000 and the 5000 trucker mirror mount antennas before. This time around I want to use an 102" whip and from what I can understand is that I'll probably have to use a spring or some kind of an extension at the bottom to make it 108" whip. I am going to mount it behind the cab of the truck on the deck plate right above the frame. My question is.....does the length of the coax matter because it's going to take more than 18' of coax to get to the radio?
