MC what brand and type of aircraft sealed rivets do you use?,
are they available in different lengths suitable for riveting thick wall tubing 1/4" or more in total wall thickness?
the sirio 827 i posted pics of uses regular rivets which makes sealing the top hub connection to the radiator very difficult causing problems with long term reliability in our weather,
some of them are glued and riveted and rely solely on one stainless hex screw for electrical contact, the ones that are not glued dont last long either once the usual crud has worked its way into the joint, a well sealed clean joint would be much more reliable imho,
thanks.
thanks.
