had to use a double male connecter to hook up a rf choke at the antenna feed of a imax..is this ok or will it need a sealent..if so would a spray stop leak type of thing do ?
You guys check out pp 112 in the AES catalog for Cross Device STUF: http://www.aesham.com/pdf/pages107-114.pdf
I never noticed that hole before. I did however notice that my SWR was higher than normal after installing a loner A99. It was fine when I put it up and after a few days the SWR raised tremendously. I just went and pulled it down. Yep, I clogged the hole with coax sealant. Water poured out.Marconi said:You also want to be careful and not seal up the drip hole in the bottom of the A99 or the IMAX 2000 with any coax seal. Look up inside the feed point and you will see a small hole next to the fitting.
