Hello,
I managed to bring the radio back to being able to receive/transmit. It does good on power. The issue that is happening is that in either SSB Mode, the signal will eventually "roll off" till no signal comes in.... The second you transmit and the relay clicks, it comes roaring back. From what I gathered, I don't think the relay is at fault. Once you switch to AM, its working just fine and the receive comes back. Its just the second you switch to either LSB or USB, it instantly goes away up until you transmit and let go, then the receive comes back for a random amount of time. It seems the longer you do transmit, the longer the receive will stay until it slowly goes away. Once the receive is gone, and if you are quick on the PTT on the mic, you can hear it barely come up and it goes away immediately.
Aside old capacitors, what other parts may make the radio behave this way?
Thanks a ton for all the help so far on the other radios.
