Got one on the way,Wondering how good it works.
got it in the mail yesterday looks a little nicer when you get it. The antenna is off to the right more ,not in the center and the screen is bright and back lit. Set it on the bench with a new 9volt and key up the handheld and the numbers change and then show frequency. Put it next to the galaxy and key up and nothing, Next to the Meter,Nothing. starts to read if I touch the antenna to the coax conector. Neex to have time to play with it a little more.
The VHF/UHF signal has more "energy" than the 27 MHz signal does. that is why it tends to pick it up easier than the RF from the Galaxy.
maybe the counter can read harmonix
