Has anyone used expanding polyurethane foam to set a tower base with? I watched a you tube video from a company called Secure Set Products that installed a rohn 45 tower with it. They then used a crane to pull the tower tip 6 foot past plumb, which was more than spec called for. It held up fine with no movement in the base. I was considering using this product to put up a 50 foot rohn 45 tower. I dont know if it will hold up as long as concrete but the video looked promising.
