I have ordered a GM and trying to get all the components to install it but I have a few questions.
At this point I will be installing the GM on a Rohn 9H50 on top of my roof, thanks to the encouragement of CDX-007. Is there any SWR adjustments on the GM? Do I need to ground the antenna or mast? Does the GM or just the mast need to be grounded? If just the mast, can it be grounded from the bottom of the mast or do I need to go to the top? What gauge copper wire do I need for grounding or can I use the more flexible braided grounding strap? If I need to attach at the top of the mast or GM, how do I secure it coming down the mast?
I think I am going to get some LMR 400 coax, do I need to loop it at the bottom of the GM so there is not any pull or stress on the PL-259 connector? How do I secure the coax to the mast? I am trying to find the 5/16" Dacron covered Kevlar but haven't been able to locate any. If anyone knows where I can order some please let me know.
Any other suggestion would be greatly appreciated!
