Several Eznec beam models
Marconi
Honorary Member Silent Key
Oct 23, 2005
7,235
2,374
343
Houston
At the request of Needle Bender, I added a Quagi reflector to compare to my Marconi 106c horizontal model. I wanted to see what Eznec indicates about the use of a Quad element for the reflector vs a yagi element.
I tweaked the loop by increasing the distance away from the driven element, and I made the quad loop larger than I expected to get these results. Making the loop bigger and further away from the driven element looks to have raised the frequency into the bottom of 28 mhz. I'll have to do some more work on this model to get it into the CB band.
View attachment Marconi 106c H 42' mast and a Quagi reflector.pdf
    535A has left the room.
  • @ AmericanEagle575:
