I'm repairing a Cobra 25 LTD that has been modded in the worst kind of way, it's a new-to-me ebay purchase. I am trying to get it respectable and close to it's factory setup once again.
I found the final transistor was blown in half when I took the lids off!
I replaced the following:
*driver (original tested ok but I changed it for one that I had on the bench)
*final (Not w/ a mosfet)
*D9
I then reformed the two spread coils the best I could, L20 is missing a slug at this point so my readings may be way off, going to fix that next. (tonight or way eeearly tomorrow)
The carrier was low (2 watts) so I added a 68pF capacitor across C46 & removed one turn off the L10 coil. This Radio now transmits a 3 watt carrier and under steady modulation it will reach almost 4 watts average power. This radio was made in the Philippines, & after reading some more [on the internet] I see the recommendation is to reduce the number of turns on L10 from 5 to 4 wraps for "better tuning".
(usually done on China models)..
Well after I had removed a turn I came to the realization that I may have only have 3 turns on L10!
[ 4 on one side and 3 on the other, it really depends what angle you look at the radio from.]
*What does shortening the coil on L10 do to the final power amplifier circuit, & will it effect bias current (or bias voltage) for the final transistor?
I have not measured bias current.
Should I locate another coil for L10 and replace the modified one, or do I even stand any risk of blowing the final transistor with this configuration?
*What is considered "Low Output" for an early nineties (factory form) Cobra 25 LTD?
Was a 2 watt carrier acceptable or even common from the factory back in those days while the radio was new? How about today?
I have never bought a new Cobra radio yet, that's why I'm asking what would have been the expected performance level for these back in the day.
* Is an "FCC 4 Watts" 4 peak watts or a 4 watt Average output?
I am going to have to use an SDR to set L20 when I transplant it.
I have a scrap Uniden 68 I am going to pull the whole inductor from instead of just using the slug.
edit #2: I tried putting just a slug in there instead of transplanting the entire inductor it might just be me but it looks like I'm getting a ever so slight increase in power output i'm kind of baffled by that.
Does this particular inductor (L20) always contain a ferrite slug for tuning purposes?
Sorry for the long winded post..
Thank You Gentlemen for any input you may have regarding some of my many questions asked here.
The main question I'm worried about is in red.
-Sam
*D9
-Sam
