Sick magnum 257
W5ORY
Aug 11, 2010
2
San Antonio, texas
I have a magnum 257 blue face that I have been using for about two years now. I love the radio but all of a sudden it decided not to work on SSB. It works well on AM,FM but no output on SSB. I have been running it at 40w on SSB and it does not get real hot but now it is cool as it can be. What might have happened? This has been the best radio I have ever had for 10m SSB, and I have had a lot of 10m radios and none can compare in any way. Your suggestions will be appreciated.
Thanks
Jim (Billygoat)
I have a magnum 257 blue face that I have been using for about two years now. I love the radio but all of a sudden it decided not to work on SSB. It works well on AM,FM but no output on SSB. I have been running it at 40w on SSB and it does not get real hot but now it is cool as it can be. What might have happened? This has been the best radio I have ever had for 11m,10m SSB, and I have had a lot of cb's and none can compare in any way. Your suggestions will be appreciated.
Thanks
Jim (Billygoat)
first off reset your cpu push and hold that button in for about 5 seconds and see what happens(cpu on board with channel cons)under speaker kind of.
  • @ Geoexplorer69:
  • @ Geoexplorer69:
