side vs back
V
vnsdeacon
Guest
Is it better no mount my antenna on my mirror or on the back of my cab? Doe's it depend on the truck.I drive a International 9100i daycab. I use a Wilson 2000 by the way.I have heard that the back of the cab is less likely to loose signal.Going around corners and such.Not to mention not haveing it ripped off by a treelimb or something. Thans
where you mount the antenna changes how it transmitts (a bit)
say you were putting on roof
middle of rood would give you most equal 360 degree transmitting
put towards middle rear and you would have best gain foward middle
put on front middle and your best is to rear center
put on rear left and transmitt best on front right
put on front left and tranmitt best on right rear
so essentually
oppisate of where antenna is mounted is where your best transmitt recive will be found
in most cases it is not dramatic
some times it can be though
    535A has left the room.
