Silver K Eagle Mic help!
211 in tha mag
411
3
Ok, i have a New Silver K Eagle mic. Im trying to get it wired up to the cobra 148 GTL. Here is what it is doing: You know how the radio receives before you put a mic in, It wil llet you receive "Just a little" and when you put your mic in it receives the proper way, kind of like a BOOST up in receive when you plug it in!
Well, when i plug mine in, it stays the same, just receive a little, BUT...... I am transmitting perfectly, just not receivieng!
I have it hooked up right (from what im reeding)
1=White
2=Shield
3=Black
4=Blue
5=Red
Yellow= Disconnected!
I went in and cleaned the points (did not need it0 but i did it just in case, and that did not help, so HMMMMMM
Need help, Thanks Bobby
</p>
Have a look at this...
148 mic inst
this used to be easy with a four wire plug........<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/ohwell.gif ALT=":">
CDX 339 Radioactive
</p>Edited by: <A HREF=http://pub86.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=audioshockwav>AudioShockwav</A>
at: 9/4/03 4:28 pm
...You know how the radio receives before you put a mic in, It wil llet you receive "Just a little" and when you put your mic in it receives the proper way...
1=White
2=Shield
3=Black
4=Blue
5=Red
Every 148gtl I have owned did not receive until the mic was plugged in. If you are getting receive without the mic plugged in then I would suspect a problem with the radio - not the mic. The wiring configuration you listed is the same that I have on file so I would say it is wired properly.
i need help with my Knight K Eagle mic im trying to find the info for the Vox add on for it anyone know anything about it?
I didn't know there was an add-on required to use the VOX feature. :confused1: I thought you locked the mic in the transmit position, activated the VOX switch on the mic then enabled and adjusted the VOX settings on your radio...
