Since I have a Super Magnum laying around with its 8 feet 3 radials, I was rhinhking about replacing the 8 short radials with the longer Super Magnum ones.
what can I expect from it ?
You can expect, that antenna will need to be shortened.
Because longer radials give marginal improvement and are mechanically problematic.
http://www.hamuniverse.com/w5altradialnotes.html
bottom table. It's about 2m antenna but principles are the same.
Mike
Ok. Probably will need to be shortened but
why ? What about performance ?
I want to replace the shorter 827 radials because I think this antenna is a 5/8 wave and longer radials should be used since the beginning.
Why Sirio used a bunch of shorter radials instead of longer ones is uncanny for me.
can eight 1/8wave radials equal three or four 1/4wave radials for decoupling the antenna / minimising cmc ?,
Alexis, is your 827 in the air and tuned to the frequency you want?
Not the charts I was looking at in the ARRL book. They cover both ground and elevated. I know the OP was talking about elevated, not ground mounted.When it comes to something like 4 1/4 wavelength or 8 1/8 wavelength radials performing about the same, and sometimes even better. This is referring to a radial system that is on or just above the earth.
I don't think that shortening the vertical element of the antenna alone will be enough to account for this change, very likely an adjustment to the antenna's matching system will be in order as well. I don't know if it will have enough tuning range to account for this change or not.
You misunderstand. The shortening of the vertical element has to be done as a result of the improved efficiency of the RF ground. And funnily enough in the same section of the ARRL book there's charts galore and a sub-section explaining that too
