Are the Sirio M400 and the Workman M400 both made by Sirio? Back in the day I had the original Starduster and really liked it. Any comment on these two copies of the Starduster?
I currently have the Sirio M400 and it is an exact copy of the star duster. My M400 has been up in the air for 15 years and I need to change the coax but it still works.Are the Sirio M400 and the Workman M400 both made by Sirio? Back in the day I had the original Starduster and really liked it. Any comment on these two copies of the Starduster?
373, below are two models at 36' feet over Average Earth.
One is a Starduster that includes a modified radial hub. However, it is very close to specs in the wire dimensions. So, it includes 4 radials and I did not add a capacitance device to the radiator. I added the four radials because of the hub modification I used.
The other model is a Sirio M400 is also close to specs. I used a simple 2" inch radial hub on this model and included the capacitance cap on the radiator per instructions.
Neither model is isolated (ISO) from the mast, however you may find you need to do something to help minimize common mode currents (CMC) on both of these antennas. Reason is...a lot depends on the installation and location when it comes to CMC issues or not.
I was a bit surprised to see both showing almost identical performance and match with a mast included in the models.
Mine is definitely a M400 and it has the billet hub. I think the sintered pot metal is Workman. The angle of the radials and be adjusted by moving the spreader assembly up or down.Mine has a billet hub so it must be a Workman?
Tallman,
all sirio antennas with "diecast" hubs are made from sintered monkey metal,
look on sirio's website at the hub, its nothing like an A/S starduster, it looks like the signal keeper loft antenna hub,
all the clones i have seen use various styles of billet hub, i have a sirio hub a cte hub and an unbranded hub somewhere in the garrage.
