s. I've seen reviews where people were saying it blows the 102 whip away.
I doubt it. I wonder who those people were and how they concluded that statement.
The reason why using a 1/4 wave whip on the CB band for instance is still superior is because there are no losses in the form of a loading coil.
All shortened mobile CB antennas have a coil form in one way or another. The reason for this is to match the impedance back to 50 ohms since the impedance is significantly changed when the antenna is shortened to a less than 1/4 wave length on any band in mobile operations.
The coil used in these shortened mobile antennas adds inductance which is electrical energy stored in a magnetic field. This coil is where your radiated losses occur from. This radiated power value is measured as ERP. (effective radiated power) after coil losses.
Just because your radio shows on a meter 100 watts output, doesn't mean your radiated power or ERP is 100 watts especially when using an antenna shorter than a 1/4 wavelength. This is the trade off for running a shorter antenna because not every mobile install can tolerate the height issue with a 1/4 wave antenna.
There are published reports in the reputable ARRL handbook from testing done with mobile coil loaded antennas. At 10 meters, (since this amateur radio testing) the average mobile antennas measured less than 70% ERP at 100 watts. That means 30% of the radio output was lost at the antenna coil and some other smaller losses too.
Now consider this, At 80 meters, the losses were outstanding at 97%. So at 100 watts on 80 meters, only 3 watts is radiated if your lucky. But consider a 1/4 wavelength antenna at 80 meters and you will need a 65 ft. antenna, not likely you will clear any overpasses with that antenna on your mobile. If you look at a Hustler 80 meter mobile antenna, notice how huge the coil is to get a 50 ohm match, that means big losses. While the antenna works, it is hardly efficient.
Now can you understand the differences between 1/4 wave antennas and coil loaded antennas? 1/4 wave antennas are superior if you can withstand the height, If not, then go with the best shortened mobile antenna like this Sirio seems to be.
The trade off with a 1/4 wave CB antenna other than the height is the feed point impedance is around 36 ohms. This is an easy fix to bring it up to 50 ohms if you have a antenna analyzer and 2 ft. of 14 gauge enameled wire like the kind used in electric motor windings and you can have a near perfect mobile antenna.
If interested I can explain making a shunt coil for a 1/4 wave antenna.
