I have my imax 2000 up in the air approximately 10' from feed point to ground.
It works surprisingly well.
My dx capabilities are excellent on SSB, but not so good on AM (unless conditions are very good.)
I recently decided to raise my 2000 to approximately 24 ft using a telescopic mast.
My reasons for wanting to raise it we're strictly to improve my DX capabilities on AM (which I've been enjoying more as of late). If the SD 27 will do what I'm hoping my 2000 will do (or better) at 24' I'd rather go with the SD 27.
With the help of a couple of site members I've decided to go with SD 27. I will be installing it in the horizontal position.
Instead of raising my 2000 to 24 ft it would be advisable for me to install the SD 27 exactly as I installed my 2000 and expected to do a better job while AM Dxing?
That would be on a non-penetrating roof mount with two 5ft masts.
In the opinion of those who know would the SD 27 do a better job dxing (especially on AM) at 10' then my imax 2000 at 24'? 100$ non penetrating roof mount, $150 120' of LMR 240 and $60 for the SD 27 is a an investment I don't mind making especially if the results for AM DX will improve. The 24' telescopic Mast is $160. I would have to purchase the lmr 240 anyway so the price difference between raising my 2000 or spending the money on the dipole, coax, and SD 27 is basically the same. I'd rather go with the SD 27 setup especially if it's going to do the DX job on AM that my Imax 2000 doesn't and or won't arrive 24'.
This is a clip of my my IMAX 2000 setup and the SD 27 would be put up exactly as the IMAX 2000 shown in the clip. Thanks for your input. 73 PS. Installing an antenna on my roof or anywhere on my homes structure is not possible.
