Ok so I have a basic understanding of quarter wave ground plane antennas, and up untill now the ones I have used had 4 horizontal wire radials so naturally only the whip radiated, but I now I own a sirio top one, with slanted radials, so my question is this, the top one is fed where the radials start so im thinking only that top section from the feed point radiates the signal, and the ground plane doesn't,? the reason I want to know is because my antenna is very low, if I am right that would mean I would only need the top section to clear the roof ? the antenna is in the garden surrounded by houses so do I only need the section from the feedpoint up to clear the roof ? or is there some radiation off the basket groundplane ? Im not sure what the takeoff angle is, but it works better than my halfwave, I assume its because im in a dip.
