Hello
I have a Sirio Turbo 3000 Pl antenna and i have a problem.
i did shorten the antenna by cutting a piece on the bottom of the antenna and not on the top.
now i can't get the swr better then 1:2.4
is it possible that the problem is there because i cut the antenna not on the top but on the bottem ?
olso same problem with a sirio AS145 PL. i have shorten it by cutting a piece of on the bottem.
on both antenna's i can't get the swr better.
the last antenna is 1:1.5 swr,, so a little better.
i think the problem is that i was stupid to cut on the bottem of the antenna ?
it goed from wide on the bottem to small on the top, both models.
sorry for the bad english !!!
greetz from Belgium.
