Sirio Vector 4000 antenna,:confused1::confused1: where to buy?
if youre not in a area that gets high winds or lots of ice in the winter it may not be durable enough for your area . you can build a very very physicay strong version for about $200 - $230ish .
Why not just shrink each piece of the radiating element farther into the one below each until the antenna is 5' shorter, then downward drill a piece of solid aluminum rod to fit into the top tube with a 68" Wilson whip and a couple of allen set screws, then adjust for swr & reactance.
I bet that would make it a sturdy sucker in high wind, but might corona discharge with high power in high humidity.
Very interested, where would I get the plans for this?? (just realized this is my first post.....yahoooo!!)
    535A has left the room.
  • @ AmericanEagle575:
