Skipper 300
Tweetybird
Jun 23, 2019
709
444
My 8950 one work good it's getting capped anyway but last I'll start learning on the 50.00 one the 8950 seems to need returning after each key up and its not modulating well its low on meter I uninstall it and modulating normal according to meter anyway ? I get 275 or so out pep after multiple rekeys but let it sit and watts drop back again guy I bought it from also said he had a siltronix 1011 comanche for sale might have been over driven what does that weaken the driver or all four tubes anyone know why it's doing this?
Has original caps
How long did you let the tubes warm up?
It's not working right as I'm learning modulation is flat has to really be heated up to make watts guy was using siltronix 1011 to drive kinda lied wha he said it works like it should wanted three hundred for it the one I paid fifty for looks easier to fix but I'm new then there is the 75.00 300a...... working on learning to upload pictures so I can show what I think I found wrong last night I was wiggling things found one of the electrolytics had a broken wire on the ground side I'm sure that might have something to do with it going to 900 watts and occiliationg I want an ociliscope tool they look cool
Then I'll have to learn how the wave is supposed to look
