Retevis is giving away Radios for the New Year and Every Member is Eligible. Click Here to see the details!
i ran across this amp and have no idea what it is as far as input wattage and output wattage.it is a mobile,with a blue face.it has it has power,preamp and am-fm cw ssb switches with a rotary knob for low,med,high and max.does anyone know?
There have been several versions, but the one with Motorola 454 transistors should be good for about 350/400 watts on SSB and stay reasonably clean.
They had regulated biasing that actually worked decent, they make a good little mobile 10/12 meter amp
Some of the later ones had 2879`s in them as well.
Not bad little amps.
Need help lost my channel chart . Cobra 148 GTL with a 8719 and 11,1125 crystal 26.175 to 28.045 , Need the chart I can fill in the blanks slide 2ck up and 12 kc down
