Cbradioman25,
Are you all wrong? No. I would hesitate to say that you are completely 'right', though. I see two areas in what you've said so far. One concerns the size of the antenna, the other concerns performance. The first part deals with the attitude of where you live and the mechanical problems with any antenna the size of a beam at 27 Mhz. You'd know more about the 'attitudes' around you than I would! Size isn't the only thing that makes something noticeable/objectionable. 'Shape' has a big part in that too. I tend not to 'notice' things that are fairly common (shape/size), but do tend to notice things that are 'different' from what I've seen before. I figure that's fairly 'normal'. Would a 'Skypper' antenna be more, or less noticeable/objectionable in your area? And would that make any practical differences in your having it?
The other 'part', the performance of that 'Skypper'. I have no experience with one. Before your post, I didn't know there was such a thing. Even with that in mind, I can say that the most noticeable (if any) difference in performance when compared to a more typical yagi type antenna, would probably be on the negative side. I have no proof of that, it's just a guess, and a sort of pessimistic one. The reason for a 'pessimistic' guess is that directional antennas have been around for a fairly long time, and all kinds of sizes/shapes have been played with. The same old typical size and shape always seems to stay around, the different ones don't seem to. If there really were a big difference, I think the 'odd' one wouldn't be so 'odd'. Make sense?
And then there's the 'practical', or mechanical aspect. What/which 'style' of antenna would be easiest for you to get into the air? For me, 'simple' is very good! I can mess up anything if it's complicated. Just depends on how much effort I'm willing to put into it, and being 'world class' lazy, oh well. That's something else you'd have a better way of judging than I would.
So, what do you think? Gonna try one? Either way, good luck.
