Rather than just let the fishing poles dictate my spacing (building a skypper) I want to use spacing that gives the best gain. .
Does anyone have models or experience with these spacing s for max gain and frt. to back?? I have used 12 foot Fiberglas pole so boom length is up to about 20 feet, taking into account the loss in distance of the bending of the poles
With poles I have in place my spacing can be from 100 inches to 120 inches from the reflector to the driven element as well as the reflector. These measurements are from the apex or farthest point from the driven element.
< I > the reflector as you know is bent towards the driven dipole in the center....I have about 20 inches of adjustment on this space? Both the reflector and director will need to have the same spacing to keep all elements on the same plane. if i use the same spacing on both the reflector and director wont this equal spacing have a negative effect on performance?
Yagi spacing on 3 elements is not as wide? Not even close. Any thoughts? Or models.
