11 METER BEAM ANTENNAS (27.025) SKYY WAVE ANTENNAS ARE FAR DIFFERENT THAN ANY OTHER BEAM WE DO USE THE SAME TYPE ANTENNA STYLE LIKE MACO BEAMS BECAUSE WE USE THERE PARTS BUT OUR BEAMS ARE SET UP DIFFERENT THE SPACING IS DIFFERENT AND THE LENGTH OF THE ELEMENTS ARE DIFFERENT I BUILT TO PROTO TYPES AND HAD GOOD SUCCESS WITH BOTH ANTENNA I BUILT A 3ELEMENT BEAM IT 13FT 9" LONG AND I BUILT THE BEAM TO DBI SPEC. THE DBI ON THIS BEAM IS 8.19DBI AND THE FRONT TO BACK RATIO IS 82.77DB GAIN AND IT CAN OUT TALK ANY 4 ELEMENT OR 5 ELEMENT BEAM AND YOU CAN HERE ALOT ON IT. THE SKYYWAVE 3 EVERYTHING COMES OUT THE FRONT OF THE BEAM. THE BACK END OF THIS BEAM IS REAL TIGHT. I JUST BUILT A 7 ELEMENT BEAM 28.50FT AND THE DBI IS 10.51 DBI AND THE FRONT TO BACK RATIO IS 86.52 DB GAIN. THIS BEAM IS WELL MADE AND WE TUNED IT TO 27.025 FREQ. WITH A 1.1 SWR WITH 500 BIRD WATTS AND IT MAKE YOU SOUND LIKE YOU ARE RUNNING BIG WATTS.
THIS EXPLAINS WHAT DBI IS.
decibels relative to isotropic radiator
The expression dBi is used to define the gain of an antenna system relative to an isotropic radiator at radio frequencies. The symbol is an abbreviation for "decibels relative to isotropic."
The dBi specification is based on the decibel, a logarithmic measure of relative power. Suppose an antenna A produces an electromagnetic field of intensity IA microwatts per square meter (IAµW/m2) in its favored direction at a point located some distance away. Also, suppose an isotropic antenna Q produces an electromagnetic field of intensity IQ µW/m2 at the same distance. Then the gain G of antenna A, in dBi, is:
G = 10 log10 (IA / IQ)
http://whatis.techtarget.com/definition/0,,sid9_gci214571,00.html
