Phil501 said:I'm thinking of running the 3 element yagi or the Maco 103C this spring.........I'm curious what the boom length is on either one......and what the spread is on the reflector.....That little superHawk has only a 5 foot boom........and 13'7" from top to bottom on the backdoor......Very small for it's 2 element performance. I didn't have a lot of room when I used it and it was perfect for me....The way I had it mounted, I had a lot of obstructions in the way, and the quad is very forgiving with SWR's in that aspect wich suited my needs.........I've never ran a yagi or Maco on the flatside, but I want to choose the best and put one up this spring.......I still have the quad, but I damaged some parts when I took it down to move into my new house. It's unoperatable do to my uninstall........(Too many Beers) .....LOL............73's all
Old Pirate56 said:Phil501 said:I'm thinking of running the 3 element yagi or the Maco 103C this spring.........I'm curious what the boom length is on either one......and what the spread is on the reflector.....That little superHawk has only a 5 foot boom........and 13'7" from top to bottom on the backdoor......Very small for it's 2 element performance. I didn't have a lot of room when I used it and it was perfect for me....The way I had it mounted, I had a lot of obstructions in the way, and the quad is very forgiving with SWR's in that aspect wich suited my needs.........I've never ran a yagi or Maco on the flatside, but I want to choose the best and put one up this spring.......I still have the quad, but I damaged some parts when I took it down to move into my new house. It's unoperatable do to my uninstall........(Too many Beers) .....LOL............73's all
Phil, I have found that the combination of a flatside beam and a vertical like the A99 or Imax is good, the vertical lets you hear everything around you and then you can just flick the switch to go flatside.
Murray
