Just for the record, whenever I hear good audio coming from US based stations I often hear "Turner" microphone in the working conditions. They sound clear and punchy on the DX (to England)
There are 2 pointers for good audio (assuming you have a 1/2 decent mic in the beginning) and I learnt the hard way, till a more experienced operator set me straight. (26CT331)
1) Don't eat the mic, keep 6 inches away. If you get too close you get a popp-y, blowy, crackle-y sound.
2) Don't over drive your linear. (Whatever you are feeding it halve it)
No. 2 took time cause more Watts is better right? Wrong. More Watts in does not mean more Watts out once you have saturated your linear. All you get is distortion and clipping which robs your audio of clarity and potentially produces RF feedback and hot finals in your transceiver. (And potentially causes unwanted RF interference to other users)
Here is a picture of where I run my Alinco into my RM KL-505 (which never sees switch setting 6) The red dot is where I peak my audio for drive into the amplifier. I now get
R5 reports across the world. The red line on the RF output level knob represents the position for peaks at 5-7 on the meter. (meter red lines)
It is worth remembering to obtain 3dB power gain on an RX S-meter you need to go from 200 Watts to 400 Watts. That is a lot of energy for a small signal increase. So to drop from 200 Watts PEP down to 150-160 Watts PEP is almost no difference at all. But all your radio equipment will be working clean and punchy like it should be and this is a very good place to be for audio quality and intelligibility.
I have a $180.00 (£130.00) rig with a stock mic, no Yaesu's, Icom's or Kenwoods here, just cheap Chinese radio with stock mic and still get R5 reports from everywhere now.
I was told (and have now learnt) it is not always the loudest voice that is heard it is often the clearest. If your words are being heard clearly and intelligible over a distorted mess you will get the call back to go ahead and complete your call.
It works.
