W
W9WD
Guest
I want to make a 2m ground plane antenna.
I saw a rather snazzy idea on a webpage. The idea was to use a piece of brazing rod as the vertical element, soldering it to the center connector and attaching the radials to the 4 holes of the chassis connector.
Brazing rod comes in different diameters. 1/16 3/32 1/8 etc.
So I'm wondering which chassis connector would accept the largest brazing rod?
It's one of the specs they never tell you when you go to buy connectors.
So anyone run into a SO-239 chassis connector that will take a very large gauge wire?
