So I was thinking about the MRF150
mr_fx
Oct 8, 2011
1,536
172
173
Kansas City
I mean it's a 150 watts and 150v right, so all you would really need is a wall socket and a rectifier/capacitor, or even run off 220 and just use a voltage regulator setup... anyone else think this is worth while project?
MRF-150 is designed for 125V @ 16A draw.
I know that your nominated supply voltage over there is 110V but what is the current rating of your standard power outlet?. you may need to upsize that power circuit or run a larger capacity circuit just for the amp. could be a costly exercise
    Will do Gary, thanks! Hopefully see you Friday next.
  • @ W4KVW:
    Rock Stars ROCKS!
    Looking forward to it Gary!
