Soldering iron
I can tell you from experience.....if you're soldering something like coax, mic,ect.....wearing nothing but shorts, keep your work over the desk,bench or table. Molten solder on a bare leg has been known to cause a rapid onset of colorfull vocabulary ;)
30watt iron for components, much larger for large transistors like you will be using. a cooler (less wattage) iron is great for a beginner or for more delicate work. i would use 2 irons if i was amp building, a very large 1/2 tip with a few hundered watts for case/ ground work. and and smaller 30-50 watt for component work.
its antex all the way for me, been using them since i was 11 years old, i also have several wellers,
do you like writing with a big fat pen or a slim pen?
http://www.antex.co.uk/
lots of different bits to choose from and the element is on the inside of the bit,
very slim and manoeuvrable especially if you get silicone cable ;)
Just about any soldering station with a 15-20 watt pencil for fine work and up to 25 or 30 watts for medium work.
If you're seriously looking for something to solder connectors, don't play around with a soldering station or ANY soldering gun.
Here is what you need for that. The 100 watt iron is perfect for PL-259s.
I've used this iron for almost 50 years. Got mine when it "only" cost $20. Been through three tips. I won't even think of connector work without this, and after you've used one and have an idea about the importance of "thermal mass", you won't either.
Peddler said:
http://www.action-electronics.com/wewlc100.htm
I have one of these...added a couple of tips and there you are.
I hope you have better luck with that iron than I did. I went through two of them at home and three of them at work.The variable adjustment kept frying.I eventually cut the cord off and put a plug on the ends making them fixed heat irons.Now I just use a big iron plugged into my variac.
:shock: OH NO not karo's american beauty lmao, hide that link beetle :twisted:
i have been using an old antex 12v 30-40w with my largest bit and crank the bench supply up to 16v or so, i agree thermal mass is very important especially for soldering the braid,
i have an old poker similar to that, its like swinging a lightsabre,
i never tried it for coax connectors but i will now theres more than one of ya saying they are the dogs danglies,
i used to collect old 100/130w 2 speed weller guns i have about 5 left i think, it takes 2 of em to solder lugs on 4awg cable, far from ideal but it works,
the best thing by far for lugs i ever saw was watching prime_ minister use his big solderpot, now that does do a superb job of saturating/soldering BIG lugs on heavy cable without melting the insulation ;)
    535A has left the room.
  • @ AmericanEagle575:
