Space Shuttle Audio Frequency listing
Ham Radio Nerd
Apr 14, 2002
9,278
1,902
283
For those who weren't aware, the audio from the Space Shuttle is rebroadcast on the ham bands for us to listen in on.
Amsat.org maintains a listing of the frequencies in the U.S. and Canada where you can find the space shuttle audio being rebroadcast in your area. Check the listing here:
Shuttle Audio Frequencies
WA3NAN,Goddard Amateur Radio Club, used to (still might) rebroadcast space shuttle transmissions on the freqs below.They also QSL SWL reports with a nice card and info sheet.
3860 KHz
7185
14295
21395
28650
147.45 MHz
  • @ Geoexplorer69:
  • @ Geoexplorer69:
