Speaking of getting a 23 channel on new frequencies....
mechanic
Mar 4, 2009
596
127
53
North coast of the USA.... Da UP!
I have a couple of Midland 23 (13-893) channel AM/SSB rigs and the are sort of locked on the 23 channels as they are crystal synthesized....
I know with a VFO they do go places, but.... I would like to try some other ideas if only for academics.... :biggrin:
Since they use several crystals to obtain their channels, a four by six plus IF scheme, Remixing different crystals should get them elsewhere. And this does the trick! I used several 10.xxx xtals and they get me below channel one but I want to above channel 23. I've tried some other xtals that are third overtone type but the go somewhere I have not found yet!? :scared:
I could build some sort of signal injector or maybe order the xtals I need but what if I take a 10.xxx and grind it down so it vibrates higher? This has been done but is slow going.... :huh:
Since this is going to be experimental this thread will have to be updated as I progress, If anyone has ideas or just wants to critique the whole thing, just send a reply.... :laugh:
mechanic
