My pics of my newly installed antenna This picture makes the antenna mast look like it is leaning but it is not. I used a level for every part of it's construction. This is a sectional mast using 4 foot sections totaling 24 feet and riveted together this is not the recommended procedure. Riveting the sections together is the only way to secure it together but mostly to prevent any twisting and the coax runs down inside the mast. You can see just the top part of the stairs which is going into the 2nd floor. All the following pictures I used the camera's zoom to see the antenna better. As I am much older now then when I was in the eighties working nearly thirty feet up and hanging off the edge was not very fun any more.
