static-electrical noise on base
S
sparkplug549
Guest
I have a lot of static on my base setup and would like to know what is the best way to quite it down some. It sounds like noise from a power line. I have a ground plane that is mounted up against the house which is about 100 ft. away from a transformer. What about grounding the antenna, radio, amp or must i get some type of filter. I plan on putting the antenna on top of my old tower which has a tv antenna on it at this time. That would put it above the power line level, would that help? Any help out there.
Thanks sparkplug549
</p>
If it is in fact the tranformer see if it can be replaced by the power company. Many moons ago I had a buddy who went round and round with a company over interference.
They did finally have to come and replace it. It seems a "stray" 22 cal. bullet had pierced the transformer and it ended up failing.
Wayne C.
CDX-787
mobile/base
Magna Force 900
HR2600/Kenwood TS-430S
MR. COILY Single Coil/Wolf .64 ground plane
D104M6B/MC-60 desk
Every man is a damn fool for at least 5 minutes every day; wisdom consists in not exceeding the limit.
</p>
    535A has left the room.
  • @ AmericanEagle575:
