Stealth antenna? Explain this one.
Explain it? Just like any other Isotron antenna, small size and poor performance as compared to a real dipole. To further explain things I would have to talk about inflated performance claims and such but I won't. :whistle: They say it performs like a dipole but they don't say the dipole is only a foot long. :laugh:
Even the ham radio world has it's snake oil antennas. It's performance is probably just a little better than a dummy load mounted on the same pole.
Dipole perfromance? Probably true if they mean loading up a 10 meter dipole on 160 meters. Oh yea....if you have room to mount that thing on a mast you have room for a dipole. :thumbdown:
The Isotron people should know better and know that they aren't fooling hams and that the hams will get them back....by not buying their products.
The funny thing is that out of 67 reviews, the Isotron antennas get a 3.9 out of 5!
One guy claimed that he took his down and put a 50 Ohm Dummy load up in it`s place and ........
Posted By
K1CJS:
I had a twenty/forty meter combination setup I traded for, and the only good thing was I could say was I had a HF antenna system up. I tried an experiment--I placed a dummy load at the end of the co-ax and raised that into the air. It worked just as well as OR BETTER than the Isotrons.
When I finally got room for a simple dipole system, I could NOT believe the difference between these 'antennas' and the dipole! It made no difference that you could tune them for minimum SWR. In my experience a simple dipole system blew these fancy 'birdcages' out of the water!
Unless you have absolutely NO choice in the matter, save your money and put up a dipole or a long wire. You'll probably be much happier.
Now in the same thread there is ....
I have the 15- and 20-meter Isotrons inside my house. It took a while, but I've got WAS abd DXCC with them (149 entities confirmed). They would no doubt work better if outside and elevated, but I don't think any other setup would work any better inside my house. Now all I need is more sunspot activity!
I will say that the Isotrons will tune up and that means an efficient transfer of signal from the antenna to the radio but the signal pickup of the antenna itself leaves something to desire.Any small antenna will not have the signal pick up that a full sized antenna will have.
Amen, my home made dummy load tunes up real nice to.
I guess they have there place, but i think I would try the dipole first.
if the band is good you would be surprised how well the worst antenna will work.
Doesn't mean it is a good antenna....
AMEN! I can't even remember the number of times I have heard someone put up a crappy antenna and then think it is great because they just talked to someone a few states away with just a two pill amp. :laugh: I talked to Florida from Nova Scotia on an indoor dipole in my basement one time with just 25 watts. It was still a crappy antenna and something I was just messing around with in my early radio days.
You can tune a coat hanger and with the right conditions talk half way across the U.S. The rest of the time it will be a coat hanger and you will be lucky to be heard across the block.
Ummm.....
Snake Oil
Couldnt ya hook up a coax to an aluminum trash can and put it 20 or so feet in the air and get just as much. And yet look more sophisticated? ;)
"Been there, done that!"
It's been something like 30 years ago, but I had to try one, you know? Got a ten meter 'Isotron' to put up at work. (10 and 11 meter, sort of.) That was one of the sorriest things I've ever had. I finally got it to tune, but it was a huge PITA! Talk about 'up/down/up/down/etc! I can honestly say that the comparison to a dummy load is a valid one. Except if a dummy load was that much trouble to use, I'd throw it away.
Take a look at what the things are. It's a tuned circuit, a coil and capacitor. One tuned it will accept power like any tuned circuit will, and it'll even radiate, sort of. But... and it's a big 'but', it don't work worth a hoot, and is not worth the money unless you absolutely can't figure any other way of going about it.
[The only tuning there is to the 10 meter version is by adjusting the capacitor thingy, and it is unbelievably 'touchy'. If a bird ever lands on it and leaves a 'deposit', the thing is no longer 'tuned'.]
'Isotron' has been around for what, 50 years at least. If the owner ever made a living from them, he had to really enjoy newspaper soup and grass salads. It's not a scam, they do work. But they work very badly.
OH YEAH ! can you remember the "PET ROCK" or K-tell ? A shit load of dumb ideas that sold millilions ? Well on his other e-bay items he has other "stelth antennas" all with 2:1 swr & over rated claims , my first thought was how they would take our winters & high winds ? Then after a secound look i think the first fat bird landing will do it in ?? However i know a lot of people that would use such a item just to talk down the street or because someone else bought it ? Nothing to do with being practical . Bob.A.
How about a Comet CHA 250BX?? I had a radio buddy 75 miles away and I couldn't hear him at all on SSB, any ideas?? I can talk 150 to 200 miles ground wave most of the time so is that antenna a junker or was it just a problem with line of sight??
    535A has left the room.
  • @ AmericanEagle575:
