I would just kinda look everything over just to make sure you didn't miss something simple. If you have a trusted cb shop near you have them bench test the amp, maybe the radio too. If everything checks out then you know it's in the antenna, coax, jumper, or install.
If it is the amp I guess you will have to decide which way to go. The Toshiba 2sc2879 was discontinued several years ago. RF Parts has a small supply of the originals left, bad news is they are 65 bucks each. X-Force sells the pp100 for I think 35 bucks.
