I have a Jetstream JTB3 144/440 antenna that I am using for my 2 meter radio.It is about 30 feet off ground to feed point using RG8X coax (mini 8)
At the 2 meter band edges ( 144.100 and 147.900 +/- on each band edge) the meter (MFJ 812B ) shows about 1.4 to 1 at the high power setting on radio but at about center band 146.500 the swr is showing just under 2 to 1.
I can understand if the swr low on one of the band edges it should rise the further you get from that point,but for swr to be lower on band edges than center of the band I find that rather unusal
I have checked the jumper from radio to meter and checked good.Coax is good,grounds in place as they should be.
All connectors are in good shape and tight on radio and meter as they should be
I have checked this with two different radios,Icom 2200H and Yeasu 2900 and the swr shows the same readings on both radios.
I also double checked the meter on my mobil set up just to see if there was something that might not be right with meter ( yea I know MFJ does not make the best equipment but it is all I have for the moment ),Yeasu 2900 into a Larson NMO 150 antenna hard mounted on my pickup.And the swr shows 1.7 to 1 on band edges as mentioned above and 1.3 to 1 center band so I am thinking the meter is fairly close...but the deal with the base antenna has me scratching my head
Any ideas anyone? Thanks in advance !!
