I think I got it figured out just want some input on this.
Shakespeare 318 antenna, pulled up a tree with rope about 25 feet off the ground.
I set coil lead length and extended the top section for 11m operation per shakespear's manual.
It is fed with about 60 feet of double shielded LMR-240
I checked everything out with the antenna about 8 foot off the ground, VSWR=1.1 @ 27.400
I then pulled it up to the top, about 25 feet off the ground and this happens
VSWR=1.4 @ 28.100 and about 1.8 @ 27.400
I lowered it back down to about 10'
SWR and center freq go back down.
I am thinking one of two things.
(1) This antenna, although it does not specify a ground plane, still needs somewhat of a ground, so instead part of the coax screws with the impedance.
Strange thing is I had the antenna in a different part of the tree at about 20 feet up before and had no issue however the coax had more belly to it, basically ran along the ground, where now it goes free space at about 45 degree angle to the ant.
and/or
(2) My improvised PL259 connector at the antenna may have broken.
When testing today I noticed the radio end was not solid and I ended up just putting a N connector that's made for LMR240 on it and a PL259 adapter
could it be something else I am missing?
and/or
