Hello Psysco:
Looks like it needs more ground plane. Temporarily add some 9 Ft long wires from the base ground and lay the wires and see if that lowers the SWR. If so ya need more ground plane area.
Jay in the Mojave
From what I see there may be a grounding issue fo rthe simple fact that most truck exhaust are mostly mounted on rubber mounts but the real issue with that antenna is that you have removed the bottom shaft section and that will not allow you to tune that antenna no matter where you mount it.
Those antennas come with 5''/10'' or 24'' shaft and is meant to use it and if you've removed it you will not easily get that antenna to tune.
Well the way I see it you've found another issue without any background on what the problem is which makes this thread pointless.The bottom of a wilson trucker coil is not flat and that coil looks flat. He must have jury rigged a 239 connector on that base. A lot of effort wasted on his part.
(edit).... the real issue with that antenna is that you have removed the bottom shaft section...
Those antennas come with 5''/10'' or 24'' shaft...
RF ground and ELECTRICAL ground are two seperate issues.
kind of hard to tell from the picture exactly what type antenna it is, but,... if it is a "center-loaded" antenna with-out the extension riser piece installed , then that is a major performance problem... (note "performance".... it has nothing to do with "VSWR", it's about efficiency). if the antenna won't "tune" then there are other problems.
to increase performance and minimize the coil losses, the loading coil should be at or near the center of a whip antenna.
Xl must equal Xc for a whip antenna to achieve resonance. the loading coil is used to tune out capacitive reactance.
going to mount a antenna lets do it right and be done
by putting half of it below the roof line ?
http://www.worldwidedx.com/installa...41-chevy-peterbuilt-custom-predator-10ks.html
