SumbandilaSat Now OSCAR 67
ARRL
Nov 15, 2008
10,591
51
58
The South African Amateur Radio satellite SumbandilaSat has been officially designated SumbandilaSat-OSCAR 67, or simply OSCAR 67. Last weekend, the satellite was successfully activated and tested with a number of contacts made through its transponder, but it is not yet open for routine use. The satellite was launched from the Baikonur Cosmodrome in Kazakhstan on September 17. The main payload is a multi-spectral imager, but the satellite also carries an Amateur Radio component consisting of a 2 meter/70 cm FM repeater. After SumbandilaSat is fully commissioned, the repeater will be activated with an uplink at 145.880 MHz and a downlink at 435.350 MHz; there will also be a voice beacon at 435.300 MHz. The transponder mode will be controlled by a CTCSS tone on the uplink frequency. SumbandilaSat was sponsored by the Department of Science and Technology and was built at SunSpace in cooperation with the Stellenbosch University. In addition to the SA-AMSAT amateur module, the satellite carries Stellenbosch University's radiation experiment and software defined radio (SDR) project, an experiment from Nelson Mandela Metropolitan University and a VLF radio module from the University of KwaZulu-Natal.
More...
    535A has left the room.
  • @ AmericanEagle575:
