Hello Ladi41:
I thought I posted a reply but maybe I clicked on the wrong button, darn keyboards.
The Switch Box and Control Box can be duplicated or copied. Relays from RF Parts can be assemblied for the Switching Box.
RF Parts is at: www.rfparts.com
I also suggest using RG142B Teflon Coax. Its the same size as the orginal RG58C Coax but 10 times more better. It will last forever and is a good investment.
RG142B coax is avialable at:
thewireman.com/index.shtml
A really good upgarde to the Super Scanner Antenna would to install Baluns at each of the elements (3ea). The Baluns do two things. 1- The Balun applies equal currents to each of the split and insulated elements. 2- The Balun isolates the RF Energy from traveling down the coaxes outer shield. And this would help out on TVI.
The Baluns are 1 to 1 Current type. Avialable at Amaidon at:
www.amidoncorp.com/aai_pr...ection.htm
Should you need any help e-mail me
Jay in the Mojave
www.a1antennas.com
</p>
Jay in the Mojave
www.a1antennas.com
</p>
