Portable 6-band 20m - 6m portable Yagi antenna The antenna isn't bad if your going to be taking advantage of the other band capabilities, for strictly 11 meters Go with the Maco or another small directional antenna....
is the yp-3 superantenna any good.how high over the mobile have to be?
yes i know it's a base antenna but instead buying super huge amp for bowl
use i get one of these.
I do believe you will need an antenna tuner with this anteny,is the yp-3 superantenna any good.how high over the mobile have to be?
