Hello TonyV 225:
Maybe you could put the Super Scanner up say 30 to 40 feet away from the A99, and do a comparison test.
I'll put money the Super Scanner will work better than the A99. But not blow it away in a significant comparison test.
I have used the older Scanner Antenna, and it was really neat to be able to quickly electronically switch the antennas direction, with just a switch. Works good on skip and local station.
The installation is not as simple as a A99 Antenna is. It will need to put on a Heavy duty Push Up or tower.
I have seen many Super Scanner Antennas installed with metal Guy Wires going inbtween the 3 elements, and that will not work. That will throw off the antennas pattern. Its necessary to guy wire the mast and right at the bottom of the antenna, because the antenna is heavier than the norm. So I suggest you use the good Black UV resistance rope sold at HRO or AES. This works great while NOT effecting the antennas performance.
Might me a neat project to work on in the spare time.
Jay in the Mojave
www.a1antennas.com <img src=http://users.joplin.com/dutch64804/posticon44.gif ALT=":44">
</p>
Jay in the Mojave
</p>
