I used a antenna analyzer to dial my antenna in exactly on a frequency. When I hook up my radio and different SWR meter, I get similar/identical readings on low power (1w DK). When I raise the variable power, the SWR goes way up, like up from 1:1 to 2:1. Is there something that I should be looking for there? I don't understand why or how that happens. The electrical connections should be good. I'm running a blue sea fuse box with positive and negative leads to the battery. The radio is a Magnum 257HP and the antenna is a Wilson 1000 mag mount.
