I ran an experiment for a topic on another forum. I am posting what I did and the results here for comments.
Namely:
Did I miss anything?
Is there something I can do to further test and refine the results and conclusions made?
Thoughts in general?
Setup:
An SWR meter, later referred to as the "test meter".
The MFJ-949E, more commonly known as the "MFJ Delux Versa Tuner II".
Varying test (or "dummy") loads to simulate different tunes on antennas.
A few short pices of RG-8X coax used to connect everything together. None of these coax lengths exceeds three feet.
Also of note is the SWR meter built into the tuner mentioned above. While not directly part of the test as it is before the variable tuning of the tuner, I did notice a correlation between this SWR meter and the actual test SWR meter so I am including it here as well. I am referring to this as the "secondary meter".
These are connected as such. The RF generator, which is an old RCI-2950 which dates from before the DX models began. This is set to deliver a 10 watt deadkey. The mic gain on the radio and the Astatic Night Eagle "lollipop"microphone have been turned all of the way down to minimize to eliminate the effects of modulation as much as possible.
After that there is a coax run using the above listed coax from the radio to the input of the MFJ-949E antenna tuner. In this tuner, before the tuning circuit, is the secondary meter mentioned above. After the secondary meter is the tuner itself. After the tuner is another piece of coax which goes to to test meter. On the output of the test meter I am plugging in the test "dummy" loads directly.
Test 1: 50 ohm test "dummy" load.
The test meter between the tuner and the 50 ohm test load showed a perfect match no matter what I did.
There were no changes in the SWR on the line after the tuner no matter how the tuner was tuned.
NOTE: This is the only test I ran before. At the time I only had a 50 ohm test "dummy" load available to me. Things have changed since then, now I have more test loads to play with.
Secondary: As I have secondary notes below, I came back to add this secondary note. The readings on the secondary meter ranged from a perfect match to off the charts. There is no correlation between the two meter readings here as the test meter always shows a perfect match.
Test 2: 75 ohm test load, produces a 1.5:1 SWR between the feedline and the load.
Running through all 12 tap points of the inductor, and on each setting adjusting both variable capacitors from their minimums to maximums and about everything in between in relation to each other for each and every tap point I do indeed have a changing SWR. However, the SWR is never higher than 1.5:1 SWR on the test meter, but I was able to get it down to a match on the test meter.
Secondary: While not directly related to the experiment at hand, on this test I also noticed a correlation between readings on the test meter and the secondary meter. When the readings on the test meter are at their lowest the readings the readings on the secondary meter are at their highest. This is also true in reverse, as one meter shows better readings the other shows worse readings. As one goes up the other goes down.
Test 3: 100 ohm test load, produces a 2:1 SWR between the feedline and the load.
Running through the settings of the tuner as I did above the same thing happened with one exception. The maximum SWR present on the test meter was never above 2:1.
Secondary: The same secondary effect happened here.
Test 3: 150 ohm test load, produces 3:1 SWR between the feedline and the load.
Running through the settings of the tuner as I did above the same thing again happened with one exception. The maximum SWR present on the test meter was never above 3:1.
Test 4: 250 ohm test load, produces a 5:1 SWR between the feedline and the load.
There is a caveat with this test. The test meter only reads to 3:1 SWR. It does have a red scale measurement area beyond that 3:1 SWR that I used for this test. I made my own mark for reference.
While I don't have the scale available to me there is still a definite high reading that is never exceeded on the test meter. This reading is clearly above the 3:1 marked reading but is not full scale.
Secondary: No change in the correlation between the test and secondary meters. Everything is as it happened above.
Test 5: 475 ohm test load, produces a 9.5:1 SWR between the feedline and the load.
This test has the same caveat as test 4. I have also made a mark for this test load for reference purposes. That point, which is further up the scale than the mark in test 4, is still not full scale deflection.
The marked high point below is still never exceeded.
Conclusion:
An antenna tuner (or the output tuning circuit in an amplifier) can in fact change the SWR as viewed from an SWR meter after it on the feedline. However, the effect it has on that SWR is limited to the mismatch that exists between the feedline and the load (antenna). Never once did the SWR on the test meter exceed the SWR of the mismatch between the load and the antenna. As the test meter maximum readings are limited to the readings from the mismatch between the feedline and the load (antenna), the tuning circuit can only make the measured readings on the test SWR meter lower, therefore a mismatch in the tuning of an amplifier output circuit can only make an SWR reading on a meter after it appear better than it actually is.
Further, while tuning an antenna tuner, or for that matter an amplifier output tuning circuit, to the lowest possible reading on an SWR meter that is in line after it only increases the SWR that exists before the tuning circuit. Any SWR that exists before the tuning circuit in an amplifier only has one place to go, and that is back into the amplifier itself. I'll let you draw a conclusion on what happens from there.
One further note. If you happen to have a perfect match between the feedline and the antenna, the test SWR meter will ALWAYS show a match, no matter how your amplifier load control or antenna tuner is set.
The DB
Namely:
Setup:
Conclusion:
The DB
