The lower the frequency; the longer the antenna needs to be.
Soooo . . . Since your antenna's SWR is getting lower as you check it on the lower part of the CB band; then I would have to say that it is too long for the upper part of the CB band.
Make sense?
yup. i had a shorter wilson 5000 whip. close i can get it to is 1.2 on 1, and 1.4 on 40.
well damn i feel dumb. i removed my magnet mount and drilled a hole onto roof for the wilson 5000. swr is 3.0 on 40, 2.0 on 1, and below the cb band its crazy flat....1.0.0. do i need to raise, or lower the whip?
you may need the 66 inch whip. I have a 1000 roof mount and that is the way i had to go to get the swr down...
